atroxsilver
Aug 28, 2023Aspirant
XR500 restarting with multiple 5G connections
Hello, let me start off by saying I am by no means a network engineer. I have been using the XR500 for a while now, and have been experiencing this issue from time to time, however it seems to...
Netduma-Fraser
Aug 28, 2023NetDuma Partner
This might be hard to resolve without some logs but we'll see if we can narrow it down. Judging by how you phrased it, it sounds like you have Smart Connect disabled is that right? If so, if you enable Smart Connect and then download/stream on those devices (so they will auto switch to 5GHz) do you get the same issue?
atroxsilver
Aug 29, 2023Aspirant
Correct, I currently have Smart Connect disabled. I will try running it with it enabled for a while.
One other thing I tried is I moved the router to a completely different wall outlet. In the past 24 hours it has only reset once while I was trying to stress it out by having a lot of devices streaming over 5G. It would usually restart multiple times per day.
Possibly a power issue?
- FURRYe38Aug 29, 2023Guru - Experienced User
Might also enable 160Mhz as well on the router.
Check the Nighthawk mobile app for Armor activation. If it's not active then your ok.What devices do you have connected on 5Ghz and what kinds if downloads or streaming are you doing all at once?
- atroxsilverAug 29, 2023Aspirant
Sorry, but what is RBR?
Nothing crazy in terms of devices - at most it's two iphones, two tablets, an xbox, a PC, and a laptop streaming. It generally restarts once 4-5 devices start streaming content, usually just netflix/youtube. Again, this does not happen if I force the devices onto the 2.4ghz network instead of the 5G one.
I meant router. Sorry about that. I get stuck on Orbi stuff sometimes.
160Mhz should be under Advanced Settings/Advanced Wireless settings.
Possible that having 4-5 devices all streaming maybe over loading the router on 5Ghz. Having too many connections could cause this.
Does the router feel extra warm or hot when this happens?
Not sure of this could help however you might try the beta FW thats over on NetDumas site for the XR500:
Not sure if that could help since there only developing and testing the DUMA OS portion of the routers FW.
