Richtoss
Dec 24, 2020Aspirant
XR500 Return Instructions
So since the RX500 model does not handle the basic functions of staying connected, Can I get the instructions to facilitate a return of the product for a full refund? I believe the instructions were...
Netduma-Fraser
Dec 24, 2020NetDuma Partner
If you want a refund then you would need to go back to the retailer you purchased from I believe.
Richtoss
I would accept a working router as well, if you have one of those.
- Netduma-FraserDec 24, 2020NetDuma PartnerI don't work for Netgear specifically, you'll have to log in here to organize a replacement, you may need to make a ticket first.
https://www.netgear.com/support/contact.aspx- RichtossDec 24, 2020Aspirant
Do you think I can get a working one or is the problem with the software on the units them selves?
- Netduma-FraserDec 24, 2020NetDuma PartnerIt's very hard to say, not everyone experiences it but I believe it is a software issue so you may not experience it on the new one but possible you would.
