johnathonm1981
Feb 23, 2018Star
xr500 RIP? Where is the SPI and NAT? Borrowed Linksys Gui? No SSH/Telnet?
Hi, So I purchased this XR500 based on the understanding that there was NAT support and SPI built into the firewall but I can't seem to find any configuration option other than old school vulnera...
Netduma-Fraser
Feb 23, 2018NetDuma Partner
Thanks for your feedback.
The 3 bar buttons are commonly used by Google & mobile apps/websites to indicate there are more options available, that's why we used it.
Usually in marketing the product will say '& comes with 30day VPN subscription trial'' or something along those lines but I get your point.
Our VPN solution will be available shortly and will allow other providers.
We haven't even hit the tip of the iceberg in terms of R-Apps, we think you'll be impressed.
johnathonm1981
Feb 23, 2018Star
Any hints as to what is to come in terms of the r-apps? I would love to personally see something along the lines of a true firewall and IPS coupled with something like Squid caching. I would absolutely pay for this type of package. Every soho router uses dnsmasq and sure, this works, but it’s not really utilizing the full potential of the router. This would be fantastic coupled with an EXT2 or 4 drive.
Another suggestion would be a more robust set of firewall rules and port blocking that we could purchase as well as import easily from you. Think ublock origin, disconnect and a solid set of lists updated regularly. I definitely feel like I do not have a very granular set of controls over the firewall and, my opinion, is it felt very open out of the box with IPSec and such being permitted along with UPNP being enabled by default. I understand that might make things easier to a degree but it also is exposing the network to the entire world in as well as our. This is also why I was very harsh on the inclusion of and use of RIP by the router. Netgear has made that very confusing is it on or off? It definitely is one that should be retired.
May I ask what QOS codec you are using or is that proprietary information? It would be great to see the something like cake thrown in with your usual asssortment. I also am assuming as a congestion algo you are using the standard cubic. Perhaps, implementing something modern like BBR would definitely have benefits for the gaming user base.
I know I am writing a lot but there is a lot of potential here and if I can stimulate an idea in any way, then I hope to try to give back. A last set of questions: if I enable telnet will that be enabled just for the internal network or will the port be open on both sides (it might be a good idea to implement drop bear so an sshd is present). Secondly, are their special credentials or am I just logging in with what I setup now. (I am off network so I can’t test it right now)-
I thank you for your time.
J
- Netduma-FraserFeb 23, 2018NetDuma PartnerIt's all under wraps at the moment so not giving away and teases right now. Great suggestions I will pass them on to the team.
QoS is proprietary yes. It's also using hardware acceleration, so we don't need to account for software jitter with algorithms.
I haven't checked that personally & there's no special credentials.
