Siku
Jan 31, 2021Aspirant
Xr500 router choking internet speed
hey! First of all, im the only one using this and i need some help :x Xr500 router keeps choking my internet. i have tried.... QoS disabled QoS enabled tried QoS enabled with different...
Jan 31, 2021Guru - Experienced User
A few questions.
1. what modem/gateway is it connected to?
2. What actual firmware is it on?
3. Is it all devices? just wired devices? Just wireless devices?
4. When it happens, what fixes it? A reboot? A full factory reset?
5. How are you speedtesting? device? app? what app?
Siku
its through a modem from the tv provider Formerly known as canal digital, Now its Telenor small black box.
i have latest firmvare on the router
Firmware Version
| V2.3.2.66 |
i only use my laptop now, wireless.
i simply fix the problem by changing settings like QoS on and off
im speed testing with telenor.no/speedometer/ and another one, i also notice the download speed on steam.
- plemansJan 31, 2021Guru - Experienced User
what telenor box is it?
steam isn't a reliable speedtest site.
try different servers on speedtest.com or google fiber's speedtest site
What wireless chip is in your laptop?
are you testing over 2.4ghz or 5ghz? 2.4ghz is much much slower
do all devices have issues? or when the slow speeds happen, do wired devices slow down?
- SikuJan 31, 2021Aspirant
well, the speed test doesnt matter to be fair, i use this a lot and it works,
i tried both 2.4 and 5, now its on auto, same result though. but will give 5ghz a try again.
i do not use wired now sadly, my mobile got higher speed, so it looks like it divides the internet even though it is not supposed to do so.
Qualcomm Atheros QCA61x4A Wireless Network Adapter, using this.
Siku wrote:well, the speed test doesnt matter to be fair, i use this a lot and it works, ----the speedtest does matter. If your main issue is speed, then it directly matters.
i tried both 2.4 and 5, now its on auto, same result though. but will give 5ghz a try again.----5ghz should be much much faster. Amost an order of magnitude faster. If you're getting the same speeds from 2.4ghz and 5ghz and the ISP isn't the bottleneck, then sometimes wrong with your device, your settings, or the router
i do not use wired now sadly, my mobile got higher speed, so it looks like it divides the internet even though it is not supposed to do so.----mwireless isn't a good test because then it bases speeds of the device and doesn't ensure the router is getting full speeds. Wireless speetesting is a nice indicator but its not the baseline because so many things impact wireless speeds. (distance, obstruction, interference, the device, etc)
Qualcomm Atheros QCA61x4A Wireless Network Adapter, using this.----have you tried other devices? this specific chipset has a ton of posts about connection issues.
