Siku
Jan 31, 2021Aspirant
Xr500 router choking internet speed
hey! First of all, im the only one using this and i need some help :x Xr500 router keeps choking my internet. i have tried.... QoS disabled QoS enabled tried QoS enabled with different...
Siku
well, the speed test doesnt matter to be fair, i use this a lot and it works,
i tried both 2.4 and 5, now its on auto, same result though. but will give 5ghz a try again.
i do not use wired now sadly, my mobile got higher speed, so it looks like it divides the internet even though it is not supposed to do so.
Qualcomm Atheros QCA61x4A Wireless Network Adapter, using this.
Jan 31, 2021Guru - Experienced User
Siku wrote:well, the speed test doesnt matter to be fair, i use this a lot and it works, ----the speedtest does matter. If your main issue is speed, then it directly matters.
i tried both 2.4 and 5, now its on auto, same result though. but will give 5ghz a try again.----5ghz should be much much faster. Amost an order of magnitude faster. If you're getting the same speeds from 2.4ghz and 5ghz and the ISP isn't the bottleneck, then sometimes wrong with your device, your settings, or the router
i do not use wired now sadly, my mobile got higher speed, so it looks like it divides the internet even though it is not supposed to do so.----mwireless isn't a good test because then it bases speeds of the device and doesn't ensure the router is getting full speeds. Wireless speetesting is a nice indicator but its not the baseline because so many things impact wireless speeds. (distance, obstruction, interference, the device, etc)
Qualcomm Atheros QCA61x4A Wireless Network Adapter, using this.----have you tried other devices? this specific chipset has a ton of posts about connection issues.
- SikuFeb 01, 2021Aspirant
i get what you are saying, but i only got this problem AFTER i got this router xr500 and every speed test is the same, is there something i can do on the router? like does it have bugs with settings? cus it IS the routers issue, im just not sure what :x
i know you want to know about other issues, but the fact that this happened AFTER i got this router.
is there something i can do on the router? settings wise?
i also can get my top speed with 2.4ghz and 5ghz.
- plemansFeb 01, 2021Guru - Experienced User
There's no magic "turbo" button to hit that fixes speed issues.
It why we ask details.
about how you're testing, what you're testing with, the gateway, etc.
And you're not actual going through the questions and answering them.
You're just going on about how its the router.
It sure could be but without details, we can't help.
If its new, you have 90 days of free phone support from date of purchase. click "mynetgear" at the top. Register an account and the device.
From there you can contact support. Might be a better option for you
erm...... i have tried to do what you ask, you are a bit rude, sorry. but done my best.
also i dont expect a magic button.
