ezambran
Jan 23, 2019Aspirant
XR500 Router Current Time issue
Hello, I have a XR500 DumaOS router with firmware v 2.3.2.40. I did a hard reboot when I upgraded the firmware from the V32 to the V40. Everything was worked well and suddenly my router changed the r...
Netduma-Fraser
Jan 24, 2019NetDuma Partner
If you go to Settings > Content Filtering > Schedule you can change the time zone there and adjust for daylight savings time
- ezambranJan 24, 2019Aspirant
I've already tried that and there's no problem with that. The problem is that the router time shows another time and another date. Even the minutes have a difference of 12.
- Netduma-FraserJan 24, 2019NetDuma PartnerAre you referring to the router time in System Information? If so once you've set the time zone do a report, does it show more accurately then? If not don't worry the WiFi scheduling should still adhere to the time zone set in Settings as it's a settings feature not a DumaOS feature.
