ezambran
Jan 23, 2019Aspirant
XR500 Router Current Time issue
Hello, I have a XR500 DumaOS router with firmware v 2.3.2.40. I did a hard reboot when I upgraded the firmware from the V32 to the V40. Everything was worked well and suddenly my router changed the r...
Netduma-Fraser
Jan 24, 2019NetDuma Partner
If you go to Settings > Content Filtering > Schedule you can change the time zone there and adjust for daylight savings time
ezambran
Jan 24, 2019Aspirant
I've already tried that and there's no problem with that. The problem is that the router time shows another time and another date. Even the minutes have a difference of 12.
- Netduma-FraserJan 24, 2019NetDuma PartnerAre you referring to the router time in System Information? If so once you've set the time zone do a report, does it show more accurately then? If not don't worry the WiFi scheduling should still adhere to the time zone set in Settings as it's a settings feature not a DumaOS feature.
