Axon
Sep 03, 2021Tutor
XR500 Router disconnecting from the WAN modem and not responding to PINGs until I reboot.
Hi folks, In the last week I have been having a problem with my XR500 Nighthawk disconnecting from the WAN link (Internet Connection) and no longer responding to PINGs or allowing to log into t...
Netduma-Fraser
Sep 03, 2021NetDuma Partner
I’d recommend you upgrade to the .120 beta release as it does have a potential fix for this issue
- AxonSep 03, 2021Tutor
Hi Netduma-Fraser,
I'm assuming that .120 Beta refers to a newer Firmware update?
I have had a look in the downloads and there doesn't seem to be an reference to that. Can you point me to where I can look at that?- plemansSep 03, 2021Guru - Experienced User
- Netduma-FraserSep 05, 2021NetDuma Partnerplemans linked it above, let us know if that helps with your issue.
