Alm28
Aug 12, 2018Follower
Xr500 router dropping internet connection
I'm not sure what's going on but my new router keeps dropping the net. The light is a soild orange color. Sometimes it blinks on and off but it's still orange. It was working fine for a few days but n...
Netduma-Fraser
Aug 12, 2018NetDuma Partner
Sent you a PM with firmware please try with that
tstrode
Sep 15, 2018Aspirant
I am also having the same issue. I currently running FW V2.3.2.32 I've had this router for about two days.
- Netduma_JackSep 16, 2018NetDuma Partner
Please could you factory reset now you have upgraded and see if that fixes your issue? This has worked for others.
- FURRYe38Sep 17, 2018Guru - Experienced User
What is the Mfr and model# of the ISP modem the router is connected too?
- t76turboSep 26, 2018Star
Just got this router today anad already having this issue. I am connected to a Netgear DOCSIS 3.1 cable modem. I dont recall the model number but can get it if needed.
I have noticed multiple drops on my iphone but the biggest indicator has been my Nest cameras dropping and sending me emails to tell me they are offline.
Nothing else in my configuration has changed other than this router. I had a Netgear R7000 router earlier today and had no drops whatsoever.
I did the firmware update as soon as I got this XR500. Looks like it updated to 2.3.2.32
Firmware Version V2.3.2.32 Firmware Version V2.3.2.32 Firmware Version V2.3.2.32 - t76turboSep 26, 2018Star
Dropped the connection again and couldnt get internet connection back. Had to break out an old Netgear router I have as a spare.
Back this turd goes. I love Netgear products. Have many, many products from them. But this particular one is not a good example. Already packaged up and return label printed.
Guess this time I will give maybe Asus a chance.
