rolly1180
Aug 21, 2020Aspirant
XR500 router. I'm getting "Resolving Host" with every browser. Help
Hello all, So today I'm getting the dreaded "resolving host" banner at the bottom of my browser...well not just Chrome but everything (Edge, Firefox...) Running windows 10 XR 500 router, fir...
Netduma-Fraser
Aug 22, 2020NetDuma Partner
If you go to the System Information page on the XR500, what does it say for the connection status?
rolly1180
Aug 22, 2020Aspirant
Hi,
The connection status just says "connected".
Oddly enough, so far this morning I haven't noticed the resolving host issue. Not sure if it somehow corrected itself on its own or what...
- Netduma-FraserAug 22, 2020NetDuma PartnerOkay well that's good, let us know if you encounter it again.
- cmarin73Sep 01, 2020Initiate
I just installed my new netgear xr500 and the first thing I noticed is the resolving host issue, it takes about 5 seconds to start loading a website. I have tested different DNS servers , no geofilter, Anti-Bufferbloat to NEVER, default bandwidth allocation. My old router an Apple Extreme never had this issue. Latest firmware installed too. Any suggestion?
Thanks
- Netduma-FraserSep 02, 2020NetDuma PartnerOpen command prompt on your PC and type ping 192.168.1.1 (if that is the IP you access the interface with) what are the results? Then do the same but using 8.8.8.8 and then let us know the results please.
