Retired_Member
Dec 14, 2021XR500 Router Intermittent Disconnections (Please help)
Router is less than a year old, has latest firmware that has been properly installed. I am not sure why my router disconnects from the internet at random times throughout the day/night. Everything e...
Retired_Member
Dec 14, 2021Done. Hopefully this resolves the issue. If not, do you think downgrading the firmware will resolve this? I only started getting this issue when I began using beta firmware. Also, when do you think netgear will have this issue resolved?
Netduma-Fraser
Dec 14, 2021NetDuma Partner
Unlikely as it was present on that version also, couldn't say exactly, hopefully for the next version
- Retired_MemberDec 15, 2021
Had it happen again. Anything else I can try? Every device has a reserved IP than falls outside of DHCP pool
- Netduma-FraserDec 15, 2021NetDuma PartnerHow often does the public IP for your connection renew? You could have the ISP extend the lease time and that could help
Looks like every 24 hours.
I had my router disconnect again earlier so I checked the logs and noticed this message around the time of the disconnect:
[DoS Attack: SYN/ACK Scan] from source: 168.119.232.76, port 443, Wednesday, December 15, 2021 23:48:38
Is this just a scan or what? When my router reconnected to the internet it shows this:
[DumaOS] DHCP lease change., Wednesday, December 15, 2021 23:50:31
Hopefully this helps you figure out whats going on, thanks.
