StevenW1230
Nov 14, 2019Guide
XR500 router internet issues
So few weeks back I was having issues with the r-app is not loaded yet. That was fixed for awhile but now it is back. Only on top of that I have even more issues now. At times the wifi will just stop...
Netduma_Alex
Nov 15, 2019NetDuma Partner
Could you go to the System Information page and increase the number of retries for launching r-apps to 6?
StevenW1230
Nov 17, 2019Guide
Netduma_Alex wrote:Could you go to the System Information page and increase the number of retries for launching r-apps to 6?
Sadly it says 6 is an invalid timeout number. I currently have it set to 5 thou for the last fix.
- Netduma-FraserNov 19, 2019NetDuma Partner5 is the maximum you can set for that option, let us know how you get on now its been set.
- StevenW1230Nov 21, 2019Guide
Netduma-Fraser wrote:
5 is the maximum you can set for that option, let us know how you get on now its been set.That is correct. I have had it set to 5 since the first fix attempt months ago. I am out of ideas as to what to try next other than getting a different router. Its annoying always having to restart it and losing internet while I am working, as I work from home and rely on my internet being stable.
- Netduma_AlexNov 21, 2019NetDuma Partner
Oops sorry I gave you the wrong number there.
