Nuts_21
Jul 19, 2020Initiate
XR500 Router is not reaching modem/router speeds
Dear all, I am making this post, because i am running out of options and have no idea where the problem is. My network structure is as follows Provider Modem/router -> ProSafe 16 port switch...
Nuts_21
Jul 20, 2020Initiate
Thank you for your reply.
I would need to take a look if your suggestions are possible the way may cables run.
All my cables are at least a Cat5e, i dont use any lower cables.
Will try to see if i can find something out this week
Regards Kim
TTNorth
Jul 21, 2020Guide
When it does a speed test it lock into that speed. I recently went from ADSL2+ to NBN FTTN in australia and it stayed at the old ADSL2+ speed. I had to do a router reset and let it do another speed test which came in alot higher and all was good.
