theRobino
Nov 29, 2020Follower
XR500 Router keeps resetting connection
Hi there,
My router keeps auto-resetting on its own and I can't figure out why. It tends to happen at least 5 times a day, but this morning it has already resetted about 10 times. When I lose connection I have verified my internet signal on my modem is perfectly fine and am confident my loss in connection is my router. I did a factory hard reset and still the same issue. Any advice will be greatly appreciated. Thank you!
What modem/gateway is it connected to?
What firmware version are you on?
How do you know its resetting? Is it rebooting? are you getting a notice "connected, no internet" actual details on what its doing helps.
- Netduma-FraserNetDuma PartnerAs above, how are you determining it is resetting and do you mean rebooting or doing a factory reset?
