SemperUdellis
Feb 09, 2020Follower
XR500 Router Keeps Resetting
My router keeps resetting. Ranging from 5 minutes apart to days apart. It appears random. But there is almost always a [DoS Attack: ACK Scan] report in the log when it happens. I looked up the most r...
microchip8
Feb 09, 2020Master
By reset you mean you lose all settings or does it just reboot? If the latter, might wanna try a factory reset and reconfigure from scratch
- michaelkenwardFeb 09, 2020Guru - Experienced User
Try the right section for your router.
Nighthawk Pro Gaming Routers - NETGEAR CommunitiesThe DumaOS people monitor it.
