SemperUdellis
Feb 09, 2020Follower
XR500 Router Keeps Resetting
My router keeps resetting. Ranging from 5 minutes apart to days apart. It appears random. But there is almost always a [DoS Attack: ACK Scan] report in the log when it happens. I looked up the most r...
michaelkenward
Feb 09, 2020Guru - Experienced User
aqx wrote:
If it say's that it is a dos attack.
Or possibly not.
Netgear's firmware is great at creating false reports of DoS attacks. Many of them are no such thing.
Search - NETGEAR Communities – DoS attacks
Use Whois.net to see who is behind some of them and you may find that they are from places like Facebook, Google, even your ISP.
Here is a useful tool for that task:
IPNetInfo: Retrieve IP Address Information from WHOIS servers
If these events are slowing down your router, that may be because it is using up processor time as it writes the events to your logs. Anything that uses processor power – event logging, QoS management, traffic metering – may cause slowdowns. Disable logging of DoS attacks and see if that reduces the problem. This does not prevent the router from protecting you from the outside world.
Netduma-Fraser
Feb 11, 2020NetDuma Partner
Good news is it isn't a DDoS attack, it is just showing connections you've come in contact with. As above do you mean factory reset or reboot?
