gdadkins
May 26, 2019Guide
XR500 Router Mode - LAN ports requesting ISP DHCP address
XR500 Router Mode - LAN ports requesting ISP DHCP address Thought I'd make a discussion to see if anybody else is running into an issue similar to mine. I've been told by my ISP that I have multiple...
schumaku
May 26, 2019Guru - Experienced User
Have by mistake any VLAN bridge or VLAN group configured to bridge the LAN port(s) to the Internet/WAN port - and bypassing the XR router NAT therefore?
- gdadkinsMay 26, 2019Guide
It's not checked as enabled. I'm guessing if it was enabled, a factory reset should fix that?
- schumakuMay 27, 2019Guru - Experienced User
Yes, of course.
- Netduma-FraserMay 28, 2019NetDuma PartnerHas your issue been resolved since doing a factory reset?
