gdadkins
May 26, 2019Guide
XR500 Router Mode - LAN ports requesting ISP DHCP address
XR500 Router Mode - LAN ports requesting ISP DHCP address Thought I'd make a discussion to see if anybody else is running into an issue similar to mine. I've been told by my ISP that I have multiple...
gdadkins
May 26, 2019Guide
It's not checked as enabled. I'm guessing if it was enabled, a factory reset should fix that?
schumaku
May 27, 2019Guru - Experienced User
Yes, of course.
- Netduma-FraserMay 28, 2019NetDuma PartnerHas your issue been resolved since doing a factory reset?
- gdadkinsMay 28, 2019GuidePerformed a reset this morning. I’ll reply back to my ISP and see if only one device is showing up in the DHCP list. I was waiting until lunch time as the lease time is four hours, so I wanted to ensure it had enough time to lapse.
