Adamr777
Mar 16, 2021Aspirant
Xr500 router, only a amber power light is on
Can’t get access to my xr500 router, as the only light that comes on is a amber power light. Iv tried all sorts of factory resetting nothing has worked so far.
Adamr777
Mar 17, 2021Aspirant
Did it step by step a few times and it said succseful, the router amber light changed to a solid white light for about five seconds and then went back to amber, the same as before
plemans wrote:sounds like you might have a corrupt firmware issue.
You can try recoving it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
Netduma-Liam
Mar 17, 2021NetDuma Partner
Which firmware is it that you're reinstalling? What's the version number?
- Adamr777Mar 17, 2021AspirantV2.3.2.114.img
- plemansMar 17, 2021Guru - Experienced User
Have you tried using an older version of the firmware?
- Netduma-FraserMar 17, 2021NetDuma PartnerAs above, try an older firmware, would also be good to do another factory reset once you've completed the TFTP transfer and waited a few minutes.
