Adamr777
Mar 16, 2021Aspirant
Xr500 router, only a amber power light is on
Can’t get access to my xr500 router, as the only light that comes on is a amber power light. Iv tried all sorts of factory resetting nothing has worked so far.
Adamr777
Mar 17, 2021Aspirant
V2.3.2.114.img
Mar 17, 2021Guru - Experienced User
Have you tried using an older version of the firmware?
- Netduma-FraserMar 17, 2021NetDuma PartnerAs above, try an older firmware, would also be good to do another factory reset once you've completed the TFTP transfer and waited a few minutes.
