Threlnos's avatar
Mar 19, 2018
XR500 Router Time
I just got this router this weekend and I have configured all the options that I want but what has puzzled me is my system info shows under the "Router Time"  UTC instead of EST.  My Geo-Filter is in...
  • Netduma-Fraser's avatar
    Mar 19, 2018
    You can change it in Settings / Content Filtering / Schedule.
    Click the pin icon and click on the map where you live. I would recommend doing the Geo-Filter tour by clicking the ? icon at the top of the page by the logos when you're on the page. That will get you to grips with the feature.
