ripper2323
Aug 29, 2019Aspirant
xr500 router what settings to use for bandwidth allocation, qos etc
I have a gigabit fiber connection 1000 up 1000 down...it seems at speedtest I avg around 400 down and 800 up.....what settings to use for bandwidth allocation, qos etc....what am I diong wrong? s...
Netduma-Fraser
Aug 29, 2019NetDuma Partner
As above, disable it via the Anti-Bufferbloat 3 line menu.
ripper2323
ok when i did that and did speed test it seems slightly better with it on is that true? or placebo?
also why is my download 1/2 that of my upload?
400 down 800 up?
- Netduma-FraserAug 29, 2019NetDuma PartnerThat can't be the case, QoS disabled should always net you the higher speeds or at least the same. Are you testing using wireless or ethernet? Have you put 1000/1000 into bandwidth settings?
- ripper2323Aug 29, 2019AspirantYes I have 1000 Putin in for each category
Ethernet
Hmm- FURRYe38Aug 29, 2019Guru - Experienced User
I would try a factory reset on the XR router and setup from scratch. Might walk thru the setup wizard, here it will detect the ISP speed, if it doesnt' detect it correctly, I would by pass the wizard, go in and disable QoS, do a full reboot of the XR and Fiber ONT and try a speed test via ethernet.
Try directly connecting to the ONT with out the XR router with the wired PC to check speeds here.
