Laryke
Apr 02, 2022Apprentice
Xr500 same ip address
Hello, I have some problems with my router, one of them I tried 30-30-30 factory reset and it wasn t working, another one is that I get same ip address all the time, even I restart the modem, change w...
- Apr 04, 2022
Laryke wrote:
I am talking about WAN IP of the router.
That is down to the ISP.
Unless your unnamed ISP allocates you a fixed or static IP address, which isn't usual, this may or may not change.
The modem picks up the IP address. Your router than uses that. You should not need to mess around with that address.
One thing to remember, you have to start the network in the correct order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
This ensures that the modem gets the WAN AP address before the router starts looking for it.
