eli5539
Oct 02, 2022Tutor
XR500 Security
When I am attempting to log in I am asked 2 security questions. When I enter them I get a message that says these are incorrect. How can I correct this
- Oct 02, 2022Good advice above, I think your only move here is to go ahead and do a factory reset
Oct 02, 2022Guru - Experienced User
are you able to log into the router? if so, you can change them from within the interface.
If not and you're getting asked them to recover the password, then you'd need to factory reset to get back in and reset those questions.
- eli5539Oct 02, 2022Tutor
No luck it brings me to password reset. When I enter my security questions it does not recognize them
- michaelkenwardOct 02, 2022Guru - Experienced User
Did you ever provide answers to those questions?
If you are trying to use the "password recovery" option, there is a bug in Netgear's implementation of password recovery on some devices. You can get locked into a closed loop.
If password recovery is enabled, but you have not set the answers to the questions, it keeps sending you back to the beginning of the process. If you haven't already given the thing your personal answers, they are not in its memory and it has no way of knowing if they are correct.
If the standard factory password (password) does not work, then you will have to factory reset the thing to get back to that. Then either disable password recovery (check the manual for your device) or provide some answers to those questions.How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
- eli5539Oct 03, 2022TutorThe odd thing about all this is I was able to update my router using my phone app. Is there anyway I can back up my home network before doing a factory reset. I probably have at least 15 devices hooked up and the thought of having to reset all of them is daunting.
- Netduma-FraserOct 02, 2022NetDuma PartnerGood advice above, I think your only move here is to go ahead and do a factory reset
