ngearftard
Jun 24, 2019Luminary
XR500 Seemingly Just Rebooted Itself
V2.3.2.40 Windows 10 64-bit Pro 1903 I finished typing a short reply to a post after logging into my (large) gaming clan's vBulletin forum, click to post it, and get a send-related error. Notice...
- Jun 25, 2019Okay that could be why, if you touch the underside of the router do you notice if it’s excessivey hot?
ngearftard
Jun 25, 2019Luminary
P.S. I did not have remote management enabled on the XR500.
Netduma-Fraser
Jun 25, 2019NetDuma Partner
Is it on a surface where it could possibly overheating like on a carpet?
- ngearftardJun 25, 2019Luminary
No, 6 ft. high on a hutch, but it's been hot as hell in the house because the ac can't keep up with the summer heat.
- Netduma-FraserJun 25, 2019NetDuma PartnerOkay that could be why, if you touch the underside of the router do you notice if it’s excessivey hot?
It's pretty warm now, even with the house starting to cool off. Let's chalk it up to that. Will let you know if issue returns in cooler weather. Thanks for the prompt replies.
