RANDOMUSER55
Oct 02, 2019Initiate
xr500 settings missing
I can log into it just fine. All the areas are on the side to click. Settings is at the bottom. When I click it, I get a blank red screen. No setting to change. I click on something else and that som...
- Oct 10, 2019
Yes, turns out the add blockers blocked the settings page.
Netduma-Fraser
Oct 02, 2019NetDuma Partner
So the Ad blocker was the problem, is that right?
- RANDOMUSER55Oct 10, 2019Initiate
- FURRYe38Oct 10, 2019Guru - Experienced User
Ah good catch. Glad its working now.
Enjoy. :smileywink:
