RANDOMUSER55
Oct 02, 2019Initiate
xr500 settings missing
I can log into it just fine. All the areas are on the side to click. Settings is at the bottom. When I click it, I get a blank red screen. No setting to change. I click on something else and that som...
- Oct 10, 2019
Yes, turns out the add blockers blocked the settings page.
Oct 08, 2019Guru - Experienced User
Any progress on this?
RANDOMUSER55 wrote:I can log into it just fine. All the areas are on the side to click. Settings is at the bottom. When I click it, I get a blank red screen. No setting to change. I click on something else and that something else shows up again just fine. When I first got the router it had settings but now there is nothing. Restarted it. Nothing. I think there was a fireware update but I don't remember if this problem started right after or not.
EDIT: Add blockers.....
