B1ggSh00t3r
Aug 22, 2018Apprentice
XR500 Setup Help - Issues / Concerns With Performance
I recently purchased the XR500 AND S8000 (bundle from Costco for price of XR500). I will try to be as specific as I can with my setup and the issues / concerns I'm experiencing.
My Setup: Cabl...
clarky1326
Feb 09, 2019Aspirant
Just seen this post but to understand everything.
Have all wired devices plugged into S8000 switch and also use another router in AP mode for WiFi.
My question is will the qos in the xr500 and s8000 conflict with each other or not work correctly?
My setup....
ISP modem(must use) > XR500 router > S8000 switch.
S8000 ports >
Port 1 Xbox one x
Port 2 Nvidia shield
Port 3 laptop
Port 4 Nvidia shield
Port 5 R8000P router AP Mode
Port 8 Uplink
My setup....
S8000 ports >
Port 1 Xbox one x
Port 3 laptop
Port 8 Uplink
Netduma-Fraser
Feb 10, 2019NetDuma Partner
Yes they probably would. I would highly suggest you disable the QoS features on the switch. The XR500 QoS is absolutely capable of ensuring your network doesn't suffer any local congestion. You would have a much better experience relying on the state of the art QoS on the XR500.
- B1ggSh00t3rFeb 10, 2019Apprentice
As far as I know, you cannot "disable" QoS on the S8000. I've checked the settings and wasn't able to find an option to disable QoS. I've have QoS enabled on the XR500 and S8000 and haven't noticed any issues w/ devices connected (wired / wireless) on my home network.
