B1ggSh00t3r
Aug 22, 2018Apprentice
XR500 Setup Help - Issues / Concerns With Performance
I recently purchased the XR500 AND S8000 (bundle from Costco for price of XR500). I will try to be as specific as I can with my setup and the issues / concerns I'm experiencing.
My Setup: Cabl...
Netduma-Fraser
Feb 10, 2019NetDuma Partner
Yes they probably would. I would highly suggest you disable the QoS features on the switch. The XR500 QoS is absolutely capable of ensuring your network doesn't suffer any local congestion. You would have a much better experience relying on the state of the art QoS on the XR500.
B1ggSh00t3r
Feb 10, 2019Apprentice
As far as I know, you cannot "disable" QoS on the S8000. I've checked the settings and wasn't able to find an option to disable QoS. I've have QoS enabled on the XR500 and S8000 and haven't noticed any issues w/ devices connected (wired / wireless) on my home network.
