flekballs21
Jan 25, 2020Aspirant
Xr500 setup to opt
Hi I’m trying to set up my nighthawk xr500, I wanted to know if I can set it up and how directly running from the OPT. I have NZ fibre100 and I seem to only be able to run it from OPT to modem to xr5...
Netduma-Fraser
Jan 26, 2020NetDuma Partner
Are you able to connect the ONT via ethernet to the XR500? You may have to get an adapter to do this. Also you may be required to enter PPPoE or VLAN settings on the router before you can directly connect the two and receive internet. Regarding the lag I would recommend you follow our optimal settings guides, particularly the QoS guide in order to resolve this: http://support.netduma.com/en/support/solutions/folders/16000090646
- flekballs21Feb 01, 2020AspirantSo I’ve just moved address so will be trying to set up and sort this coming week. I’ll receive my internet providers modem tomorrow. There is an Ethernet port on the ONT that says internet and I can plug this in directly to the XR500’s internet port via Ethernet cable.
In regards to VLAN and PPPoE, I don’t actually know how to set this up. Will I need my Internet providers modem before I can set this up and where do I start?- Netduma_AlexFeb 03, 2020NetDuma Partner
I imagine you will need your internet provider's modem before you can do anything, especially if you're moving to a different provider.
They'll also need to set up the connection from their end. But in theory you just connect the ethernet port on the modem to the yellow WAN port on the back of the XR500 and perhaps do a factory reset to get it started.
- flekballs21Feb 04, 2020AspirantSo I’ve done a bit of information research. It’s actually quite frustrating at how limited information Netgear supplies to set up the XR500, I’ve had information that has said the it’s designed to run directly from an ONT without needing a Modem. I’ve tried setting this up but got no where even with my ISP giving me a link to configure a modem/router that isn’t provided by them. I’ve also had information saying that the XR500 needs a modem to run (so purchasing something else) none of this information has been obtained from Netgear thus far
Coming to a realisation that I probably can’t run the router directly from the ONT or at least if you can I won’t be able to achieve as there isn’t enough information for people that wouldn’t even know where to start to set up there internet.
Another issue I’ve come across is there is no recommendation for what modem would be good to pair with the XR500 for a fibre+ set up
My ISP has provided an ASUS modem/router which does all right but would rather set up the XR500 since I’ve spent the money for it.
Any help would be appreciated and excuse me if I come off a touch rude I’m just quite frustrated with this whole set up process.
