michaelaulia
Jan 31, 2019Guide
XR500 short circuiting?
There was a power shutdown at my home yesterday and I noticed my Wi-Fi was gone after it came back up. So I tried to turn the XR500 off and on again but still can't see my network. I notice that only the Eth and USB power LEDs are lit (the 2.4Ghz, 5GHz, and even the Power are off - weird).
Tried using a pin to reset and even a hard/factory reset. The router was not responding to the pin press (i.e nothing was happening). I tried moving to a different power point of the house, and even tried a power adapter from my old X4S router. Still the same.
Do I have a faulty hardware? I tried searching for support but it looks like you have to pay for premium support if I had the router more than 90 days? I got it October last year, thanks
Video showing when I powered it on: https://www.youtube.com/watch?v=3h3pS0l6IW8&feature=youtu.be
- Netduma-FraserNetDuma PartnerYeah that looks to me like the power outage has blown it unfortunately. I'm unsure of the warranty period the Netgear offers. Are you unable to contact support for a possible replacement?
Ow, I see :( I was installing solar at home so they turned the power off on the panel for an hour (but my fridge and the rest of the house came back fine, just the XR500).
I actually got it from the PR team to review last year, I'll try contacting them to find out. So with the support, I had to get the Premium support in order to contact them? "NETGEAR provides complimentary technical support for NETGEAR products for 90 days from the original date of purchase"
- Netduma-FraserNetDuma PartnerAhh I see, in that case you should have an email you can contact rather than purchasing their support package?
