sassyangies
Jan 12, 2021Aspirant
XR500 showing my printer offline
I know this has been asked before, but I'm not finding a solution to my problem. I have an HP printer that all of a suddenly is showing offline, even though it's not. I've had it hookedup since I got...
Netduma-Fraser
Jan 12, 2021NetDuma Partner
It will say online if it's not being used, if you actually try to print over the network does it work correctly?
- sassyangiesJan 12, 2021AspirantNo it will not print anything. Funny thing though. There other printer that is currently packed away it shows that there as being online.
- Netduma-FraserJan 12, 2021NetDuma PartnerAre you able to try a reconnect to the WiFi on the printer itself and see if it then appears?
- sassyangiesJan 12, 2021AspirantOk I just tried that, but nothing. :(
