Risqaye
Oct 05, 2021Guide
XR500 Slow ethernet fast wifi
I recently purchased a Nighthawk XR500 router. When connected to my modem I'm only getting about 20mb download and like 1 upload. My wifi gets 240mb down and 20 up. I've replaced my ethernet cable ...
Netduma-Fraser
Oct 05, 2021NetDuma Partner
Could you provide a screenshot as an attachment here of your Device Manager table view please?
Risqaye
Oct 05, 2021Guide
Yes sorry I just got back home.
- Netduma-LiamOct 06, 2021NetDuma Partner
Everything looks OK there, could you confirm if all devices are having this problem or is it just your PC?
How did you disable QoS? I'd suggest doing so by clicking the three-line menu in Congestion Control and tick the box 'Disable QoS'.
Another thing to check, if you go to the three-line menu in Bandwidth Allocation, is Share Excess ticked?
- RisqayeOct 06, 2021GuideWhen I get home I'll hook my Xbox one up to it and see if it's affected the same way but my pc is the only thing I use Ethernet for.
Also, I turned QoS off on the qos page. In the section above listed something like Anti-Bufferfloat.- RisqayeOct 06, 2021GuideAnd that is checked I made sure that it was
