Risqaye
Oct 05, 2021Guide
XR500 Slow ethernet fast wifi
I recently purchased a Nighthawk XR500 router. When connected to my modem I'm only getting about 20mb download and like 1 upload. My wifi gets 240mb down and 20 up. I've replaced my ethernet cable ...
Risqaye
Oct 05, 2021Guide
Yes sorry I just got back home.
Netduma-Liam
Oct 06, 2021NetDuma Partner
Everything looks OK there, could you confirm if all devices are having this problem or is it just your PC?
How did you disable QoS? I'd suggest doing so by clicking the three-line menu in Congestion Control and tick the box 'Disable QoS'.
Another thing to check, if you go to the three-line menu in Bandwidth Allocation, is Share Excess ticked?
- RisqayeOct 06, 2021GuideWhen I get home I'll hook my Xbox one up to it and see if it's affected the same way but my pc is the only thing I use Ethernet for.
Also, I turned QoS off on the qos page. In the section above listed something like Anti-Bufferfloat.- RisqayeOct 06, 2021GuideAnd that is checked I made sure that it was
- Netduma-FraserOct 06, 2021NetDuma PartnerDid you select Never on Anti-Bufferbloat or actually from the menu as Liam mentioned? It's a bit of an odd issue as there are no settings that would specifically apply to wired devices. Where are you testing the speeds exactly?
