kenyz-21
May 27, 2019Aspirant
xr500 slow mbps
i cant use my internet speed i test it on speedtest.net but i only have 5-6mbps and originally i have a 1gpbs here in japan when i use my old router my internet speed was like 624mbps
May 27, 2019Guru - Experienced User
What FW is currently loaded?
Wired or wireless speed testing?
Netduma-Fraser
May 28, 2019NetDuma Partner
Are you testing using an ethernet cable and have you disabled QoS in Anti-Bufferbloat options? Sometimes it can take time for the modem to adjust to a new router, during that time the speed can be slower. You could give the XR500 the MAC address of the previous router in Internet Setup and this may resolve it.
- kenyz-21May 29, 2019Aspirant
yup im using cat7 ethernet cable and i disabled the QoS and options in anti bufferbloat. i didt try the MAC address of my previous router but im gonna try it now tnx for advice
yup im using cat7 ethernet cable and i disabled the QoS and options in anti bufferbloat. i didt try the MAC address of my previous router but im gonna try it now thanks for advice
