kenyz-21
May 27, 2019Aspirant
xr500 slow mbps
i cant use my internet speed i test it on speedtest.net but i only have 5-6mbps and originally i have a 1gpbs here in japan when i use my old router my internet speed was like 624mbps
May 29, 2019Guru - Experienced User
What is the Manufacturer and model# of the ISP modem the NG router is connected too?
- Netduma-FraserMay 29, 2019NetDuma PartnerDid you try the MAC address suggestion I gave you?
- kenyz-21May 30, 2019Aspirant
i tried it but it didnt work i try my speed test in my old router i got this speed in speed test but in my netgear xr500 i only have 20-50 mbps by the way i am using PPPoE
- FURRYe38May 30, 2019Guru - Experienced User
Can you configure the modem to use PPPoE then reconfigure the XR router for DHCP on the WAN side? Might do a factory reset after the modem is configured.
