Chowningr
Nov 30, 2019Aspirant
XR500 Speed Problem
Recently purchased an XR500 from Amazon. I have AT&T Fiber with Gigabit speed. I am currently getting nowhere near my rated speeds since using the XR500. Running a speed test on my PC gets me about 32...
Chowningr
Disabled the Smart. I am connected to 5GHz on WiFi and disabled QoS. Now speed is about 22MB/s. When connected by Ethernet I get a speed of 43MB/s. Still terrible.
Netduma-Fraser
Nov 30, 2019NetDuma Partner
What speedtest site are you using to test this? It can be the case that when introducing a new router into your connection that it takes a little while to sync up with the ISP, during which speeds can be reduced. Try giving the router the MAC address of your previous router in Internet Setup as this may counteract it if thats the issue.
- ChowningrNov 30, 2019Aspirant
I tried to MAC swap trick. Only increased speeds minimally, been using speedtest.net
Call ISP, AT&T, and they say everything is set up properly on their end.
- Netduma-FraserNov 30, 2019NetDuma PartnerWhat is the ethernet cable cat that you're using to connect the modem to the XR500? Did the XR detect the correct speeds during the setup wizard?
The XR500 detected around 750MB/s.
It is a Cat5 cable
