Raansu
Nov 05, 2021Tutor
XR500 Speed tests
Recently I upgraded to 1Gbps internet speeds and while speed test on websites are hitting roughly around 900-930Mbps (which is typical of ISP's) when I do a connection benchmark within the XR500 rout...
Nov 06, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk Gaming Router products. Most of the people who watch that forum are more likely to have experience with NH gaming router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-Routers/bd-p/en-home-nighthawk-pro-gaming-routers
I see this as well on my XR450 with newest FW loaded:
I presume this is a speed test app issue though the speed reported in text is right but speed graph is not right:
Thank you.
- Netduma-FraserNov 10, 2021NetDuma PartnerAs mentioned above, we're still working on the Benchmark speed reporting so if the other speedtests are giving you good results then that is what you're getting
