Wizardofnos07
Dec 18, 2018Aspirant
XR500 Speed/Bandwidth Allocation not working .. ..
I have a dedicated connection of 600down/30up to my Xbox One X.
My XR500 is hooked up to a cable-modem that is run in bridge mode for complete pass-through.
I have no other devices running throug...
Wizardofnos07
Dec 19, 2018Aspirant
Hi there,
Yes, I do have it set to "Always" mode.
Should I be setting it to "When high priority traffic detected" instead?
I'll go through the guide here real quick, thank you.
Wizardofnos07
Also, does it still make a difference what percentage I have the Anti-bufferbloat set to knowing that I have no other devices or traffic on this network, as it's a dedicated gaming connection only?
Same question for the setting of "Always" or "Only when high priority traffic detected", because again there is no other traffic on this connection.
Thanks
- Netduma-FraserDec 19, 2018NetDuma PartnerAlways mode is fine. The percentage isn't as important given your situation. Do you use IPv6, PPPoE or VLAN by any chance?
- Wizardofnos07Dec 19, 2018Aspirant
Hi,
As far as I know, I use IPv6
- Netduma-FraserDec 19, 2018NetDuma PartnerCould you try disabling IPv6 please and see if that fixes the issue
