djgraff209
Jan 30, 2020Aspirant
XR500 Static Route dropping packets
I'm running into an issue with my XR500 router. I'm running the lastest stable firmware (check from router indicates latest version). I have a virtualization server that I'm hosting a Linux bridg...
Netduma-Fraser
Jan 30, 2020NetDuma Partner
It could be QoS related - how did you disable it? It should be disabled from the Anti-Bufferbloat 3 line menu to make sure. How do you have your router setup as well?
- djgraff209Jan 31, 2020Aspirant
I went into the administrative screens, under QoS set anti-buffer bloat to Never, turned off traffic prioritization.
There are no geo-filter devices set.
My network is a little more complex than most.
I have disabled DHCP on the router. I have a linux server hosted on 192.168.1.2 configured to serve DHCP & DNS functions.
Network is configured as 192.168.1.0/24.
I have a linux virtualization server hosted at 192.168.1.26 (static IP). Underneath that server I have a linux bridge configured to host a virtualized set of networks (currently 1) in the 172.16.0.0/12 range. The hosted virtual network is 172.16.1.0/24. I have configured routing and masquerading and am able to successfully reach hosts on that network as well as have them reach the internet and local lan.
- Netduma_AlexFeb 03, 2020NetDuma Partner
Try completely disabling QoS. On the anti-bufferbloat panel, there's a side menu which contains a full Disable for QoS. This will allow us to narrow down the problem.
- djgraff209Feb 05, 2020Aspirant
I'm currently traveling for work and don't have access at the moment to try any changes.
I will attempt that hopefully this weekend.
What impact would turning those features off have on my network?
