Soloflyerz
Jul 06, 2018Guide
XR500 still reboots every day
So I’ve been having this issue on and off since a couple weeks after I purchased this router from Best Buy. I’d assumed that firmware updates would eventually fix the issue and actually thought it h...
Netduma_Jack
Jul 14, 2018NetDuma Partner
Hi Solo - sorry to hear you're having all these problems.
You should be able to contact support here: https://www.netgear.com/support/contact.aspx
If you enter in your router's serial number it should recognise you as a recent customer.
Let me know if you have no luck by through that link emailing us at [email protected] and we can elevate this with NETGEAR.
Soloflyerz
Jul 14, 2018Guide
Thanks sorry getting so frustrated, this things just driving me nuts and cost me another W last night when it crapped out again.
