Tones81's avatar
Tones81
XR500 Stops working
Hi All,
Hoping to get someone with experience in reading and understanding logs. For a while now I've been experiencing issues where my XR500 requires a reboot (generally once a week) as everything just stops working. Upon rebooting it all works okay again.
Latesly it's been happening more frequently so I started taking note of the logs when it occurs and have noted a consistent theme. I'm getting the below message in my logs:
[WLAN access rejected: incorrect security] from MAC address b2:39:56:ae:3a:47, Wednesday, November 20, 2019 13:06:29
[WLAN access rejected: incorrect security] from MAC address b2:39:56:ae:3a:47, Wednesday, November 20, 2019 13:06:25
[WLAN access rejected: incorrect security] from MAC address b2:39:56:ae:3a:47, Wednesday, November 20, 2019 13:06:22
[WLAN access rejected: incorrect security] from MAC address b2:39:56:ae:3a:47, Wednesday, November 20, 2019 13:06:19
It's literally just this over and over again. Can anyone decipher what this means and if it's playing a role in the issue I'm experiencing?
I can't find anything in my network with that MAC address.
I've done a lookup on the MAC address and it says it's not found so can't even find the manufacturer.
  • Well on face value it looks like something is trying to connect to your network and it's using the wrong password.
    Perhaps a neighbor's device?
    • Tones81's avatar
      Tones81
      Thanks Alex, that's what I assumed as well.
      Could it be related to the issue I'm having with disconnects? Is there a way to just block that MAC address from being able to access the network?
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        It seems unlikely unless after a certain amount of tries it blocks access completely to the internet but I haven't heard of it doing this. No not currently.
