AlexPausteck
Sep 28, 2018Tutor
XR500 Stuck on 90mbps down on 350mbps down connection
Any time I need to downloand something quickly, I need to restart the router. This is happening on two different router firmware's. Is this a known issue. My router hasn't acted 'normal' since purchase a few months ago. Becuase of this bug.. Qos doesn't work like it should.
I've been hoping for firmware to fix this issue, but nothing seems to have materialized yet. Any ideas how to procede? I don't think constant rebooting is an acceptable solution to this issue.
Thanks,
Alex
- Netduma_JackNetDuma Partner
Hi Alex - are you testing this wired or wirelessly?
The reason I ask, is 2.4GHz WiFi is usually limited to around 90mbps, so my guess would be that you are testing with a device that has connected to the 2.4GHz band. If you repeat the test wired, do you then get full speeds?
Wired, QoS disabled. I have wireless devices connected, though. I'd hope the LAN connection is not somehow being defaulted to the highest throughput of my WIFI connection. Only reason I bring that up as a theory -
- I work from home. During the day when I'm the only user, a reboot would bring my LAN speeds back to 350mbps down.
- At night with other bandwidth users when I rebooted, my LAN speeds stayed at 90mbps down.
Turning the Wifi radio off in advanced settings and rebooting did not fix it. So scratch that theory.
