sg6969
May 25, 2020Follower
XR500 support Netgaer WIFI 6 Mesh?
I've been having issues getting the wifi 6 Mesh to work with my XR500. So I figured I would ask you guys & gals? Thanks
May 26, 2020Guru - Experienced User
Did you get a different wifi 6 mesh system? If so, you need to turn OFF the wifi radios on the XR router and just run the wifi 6 MESH system as your wifi source. I have a Orbi AX system configured for AP mode. Works behind my XR450 router with its' radios turned OFF.
sg6969 wrote:I've been having issues getting the wifi 6 Mesh to work with my XR500. So I figured I would ask you guys & gals?
Thanks
Netduma-Fraser
May 26, 2020NetDuma Partner
Could you explain the exact issues you're experiencing please?
