XR500_Issues
Jan 11, 2020Guide
XR500 The operation is taking longer than expected. Please briefly wait before using this R-App.
R-Apps would not load with FW XR500-V2.3.2.56. Tried factory reset, changing timeout from 3 to 5 and cleaning cache on Chrome and Firefox with no luck. Logging in with a different computer on LAN di...
Netduma-Fraser
Jan 11, 2020NetDuma Partner
Does it show the whole interface as a white page showing R-Apps not loading or is it on a per page basis? If it's the former you should be able to upgrade back as it was a temporary error on our side that has been fixed. If the latter do you have a Nintendo Switch? If so change the device type in the Device Manager to a different console, does that fix the issue?
- XR500_IssuesJan 11, 2020Guide
Thanks for your quick reply. With FW 2.3.2.56 it shows a red background and spinning for each of the R-Apps on each of the pages (QoS, Geofilter, Device Manager, Network Monitor) until "the operation is taking longer..." message comes up. This does not happen with FW 2.3.2.40 which I downgraded to earlier today. I am connecting directly to the router IP. I only have PC's, Roku and Apple phones on the network. I am using the Playstation profile for the PC because the PC profile does not Geofilter for Destiny 2, whereas the Playstation profile seems to work ok.
- Netduma-FraserJan 11, 2020NetDuma PartnerWhen did the issue start happening? Do you access using HTTP or HTTPS? Does it occur on any other browsers?
Issue started happening with the update to FW 2.3.2.56. I used http:// for the connection to the router. It occured on Chrome and Firefox on two different PC's. I cleaned the cache on both Chrome and Firefox.
