XR500_Issues
Jan 11, 2020Guide
XR500 The operation is taking longer than expected. Please briefly wait before using this R-App.
R-Apps would not load with FW XR500-V2.3.2.56. Tried factory reset, changing timeout from 3 to 5 and cleaning cache on Chrome and Firefox with no luck. Logging in with a different computer on LAN di...
Netduma-Fraser
Jan 11, 2020NetDuma Partner
Does it show the whole interface as a white page showing R-Apps not loading or is it on a per page basis? If it's the former you should be able to upgrade back as it was a temporary error on our side that has been fixed. If the latter do you have a Nintendo Switch? If so change the device type in the Device Manager to a different console, does that fix the issue?
XR500_Issues
Jan 11, 2020Guide
Thanks for your quick reply. With FW 2.3.2.56 it shows a red background and spinning for each of the R-Apps on each of the pages (QoS, Geofilter, Device Manager, Network Monitor) until "the operation is taking longer..." message comes up. This does not happen with FW 2.3.2.40 which I downgraded to earlier today. I am connecting directly to the router IP. I only have PC's, Roku and Apple phones on the network. I am using the Playstation profile for the PC because the PC profile does not Geofilter for Destiny 2, whereas the Playstation profile seems to work ok.
