wvubrad's avatar
wvubrad
XR500 Throughput
Hi all,   Hoping someone can help me out there.  I'm looking to replace my NetDuma R1 with the netgear XR500 with dumaOS.  I'm looking for a technical specificaiton that is missing from every data ...
  • Netduma-Fraser's avatar
    Netduma-Fraser
    Mar 07, 2018
    I understand, the XR500 will allow you to get your full speeds and it can absolutely handle QoS at Gigabit speeds as well!
