wvubrad
Mar 07, 2018Aspirant
XR500 Throughput
Hi all, Hoping someone can help me out there. I'm looking to replace my NetDuma R1 with the netgear XR500 with dumaOS. I'm looking for a technical specificaiton that is missing from every data ...
- Mar 07, 2018I understand, the XR500 will allow you to get your full speeds and it can absolutely handle QoS at Gigabit speeds as well!
Netduma-Fraser
Mar 07, 2018NetDuma Partner
Hi Brad, forgive me if I'm missing the point entirely but really the limitation here would be the WAN port which is gigabit so you would never get more than 1gb regardless
wvubrad
You're absolutely correct. The netduma R1 has a maximum throughput of 500Mbps with it's feature set enabled, although it has 1Gbps ethernet ports. My internet connection is a 1Gbps connection. I want to make sure i'm not making the same mistake twice.
- Netduma-FraserMar 07, 2018NetDuma PartnerI understand, the XR500 will allow you to get your full speeds and it can absolutely handle QoS at Gigabit speeds as well!
