Gidgriff
Nov 08, 2022Guide
XR500 to replace Sky router on FTTP
Hi guys, looking to replace my sky Q router with the XR500. Has anyone done it? I have tried and it asks for generic logins from ISP which I found online but still cannot get it to work. Anyone manage...
- Nov 09, 2022Go to the Settings page and the first page it gives you, Internet Setup, scroll all the way to the bottom and it should be there
Netduma-Fraser
Nov 09, 2022NetDuma Partner
Do you know which details are required to get a connection? Does it use Option 61?
Gidgriff
Nov 09, 2022Guide
Pretty sure it’s Option 61. But can’t even find that option on settings.
- Netduma-FraserNov 09, 2022NetDuma PartnerGo to the Settings page and the first page it gives you, Internet Setup, scroll all the way to the bottom and it should be there
- GidgriffNov 09, 2022GuideFound it! Wasn’t showing on the PPPOe section so changed it and I’ve found it! Thanks guys 🙂
- michaelkenwardNov 09, 2022Guru - Experienced User
Gidgriff wrote:
Found it! Wasn’t showing on the PPPOe section so changed it and I’ve found it! Thanks guys 🙂Did it fix the thing?
If so, mark this as solved and you'll help any poor soul who lands here with the same challenge.
