Gidgriff
Nov 08, 2022Guide
XR500 to replace Sky router on FTTP
Hi guys, looking to replace my sky Q router with the XR500. Has anyone done it? I have tried and it asks for generic logins from ISP which I found online but still cannot get it to work. Anyone manage...
- Nov 09, 2022Go to the Settings page and the first page it gives you, Internet Setup, scroll all the way to the bottom and it should be there
Gidgriff
Nov 09, 2022Guide
Pretty sure it’s Option 61. But can’t even find that option on settings.
Netduma-Fraser
Nov 09, 2022NetDuma Partner
- GidgriffNov 09, 2022GuideFound it! Wasn’t showing on the PPPOe section so changed it and I’ve found it! Thanks guys 🙂
- michaelkenwardNov 09, 2022Guru - Experienced User
Gidgriff wrote:
Found it! Wasn’t showing on the PPPOe section so changed it and I’ve found it! Thanks guys 🙂Did it fix the thing?
If so, mark this as solved and you'll help any poor soul who lands here with the same challenge.
- GidgriffNov 09, 2022GuideYes it did! Basically had to bypass the initial set up to get to that part. But all good!
